跳转到主内容
索尼笔记本电脑的维修指南。
414 个问题 查看全部
My laptop suddenly died!
Hi guys! Please help...I've been using my Sony laptop probably for more than 5 years & it always worked perfectly fine! Then suddenly one day, While I was speaking on skype, The screen suddenly froze and made this whizzing noise if you get what I mean? This is probably my mistake & the reason why the laptop died but I tried to switch it off so maybe it will work when I switch it back on. But nothing happened. It din't switch off or anything so I just closed the laptop and went to do my work. The next day (When I suddenly needed the laptop), It was dead! I mean, It was off & din't switch on. I tried my very best to switch it on but I couldn't do anything & still can't. I don't think there's any problem in the battery! The only thing it does now is it shows me some lights when I plug in the charger like it usually does. And once, I tried to switch it on and the lights came on and it made the 'Starting Noise' (The sound it makes when I usually switch on my laptop!) but unfortunately, the screen was still black and nothing happened! Anyway I can fix this? Any help will be great! Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
What model is this Sony Laptop?
完成的
添加一条评论
5个答案
已选择的解决方案
It could be a problem with static discharge , if so do the following.
1. Disconect the power cord
2. Remove the battery
3. Hold down the power button for 30 seconds , then release for 30 sec and then hold down for another 30sec
4. Plug in power ,replace battery and power on laptop.
If this causes no Joy try this.
Remove memory and reinstall one stick at a time, if there are more than 1 dimm of ram, try each stick in each slot one at a time to see if the memory is ok and to determine if one of the memory slots is bad.
Hope this helps
这个答案有帮助吗?
得分 2
3条评论:
Hi Jimfixer! Unfortunately, I tried it earlier and it din't work:( Thanks anyway!
完成的
My laptop is Asus and I just brought it but when i use around 30mins..it suddenly dead..please can you solve my problem
完成的
My laptop’s battery is locked inside the system. It cannot come out without you unscrewing the back panel. It’s a Lenovo Ideapad 110.
完成的
添加一条评论
that's gonna be hard one....
battery? i don't think so
maybe the screen died, try to connect it to monitor and than power it up
if nothing open it up and check on it, board damage, blown stuff etc. (wear antistatic eq)
if you find something post pictures
and let us know whatever it does work with external monitor or not
这个答案有帮助吗?
得分 0
1条评论:
Yes, I think that's the problem! I'll try that!
完成的
添加一条评论
This can happen because of the following reasons
Motherboard failure
Ram not working or not inserted properly
Virus issue
Dust issue
but it can be solved if you take your laptop to dell customer care for repair.
这个答案有帮助吗?
得分 0
添加一条评论
If you are under warranty, call to take the support. The problem is a bad DC input socket either on the power board. The blue light not staying on is probably because of a short circuit. This is a common problem with all laptops because it is easy to break internal connections if the power cord is pulled or kicked. Be aware that if the laptop looks like it has been dropped or abused, It may not cover the problem, as it could be considered accidental damage. If it has accidental damage coverage available for all laptops. If you buy an expensive laptop, you should get this as well as extended warranty coverage for as many years you think you will keep the laptop. If you have a cheaper laptop, the extra insurance is probably not worth the expense. If you still getting issue you can take the suggestion from the Toshiba Support and it will work because I had solved my problem only because of them
这个答案有帮助吗?
得分 0
添加一条评论
Hello there!
I'm sorry to hear that your laptop suddenly died. That can be a frustrating experience. If you're in the market for a new laptop, I would highly recommend checking out the Intel Evo laptop. The Intel Evo platform is a new fleet of powerful and sleek laptops with 12th Gen Intel Core processors and Intel Iris Xe graphics. These laptops are engineered and verified to give you the best overall laptop experience, with all-day battery life, fast charging, and a thin, light, and fast design to keep up with all you do.
Intel Evo laptops are designed to deliver the ultimate mobile experience, with touch screens and other innovative screen options. They also come with accessories that are optimized to run best with Intel Evo laptops, such as select Thunderbolt and Bluetooth accessories. Overall, the Intel Evo laptop is a great choice for anyone in need of a new laptop. They are built for what IT needs and what users want, with hardware-based security features and remote manageability. You can find Intel Evo laptops from a variety of brands, such as Dell and Lenovo. So, if you're looking for a laptop that has it all, be sure to check out the Intel Evo laptop!
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Abdul Haadi 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 14
总计 18,135
