跳转到主内容
Repair guides and support for the third generation of C/K pickup trucks.
28 个问题 查看全部
Gas mileage really sucks?
It sucks gas I know it's a 350 with full time four wheel drive but I should be getting more than 4 mpg
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
3个答案
已选择的解决方案
I'd take it in to an AutoZone and get a free computer readout to try to see what's wrong. Also see if the the four wheel is engaged all the time.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
Hi,
Maybe you should consider a tune up for your vehicle. Google how to tune my chev pickup.
这个答案有帮助吗?
得分 1
添加一条评论
you can save serious gas mileage get a set of warn hubs so you can technically be running 2 wheel drive you can unlock and run too high also it's probably a good idea to tune up your engine spark plugs fuel filter oil change air filter PCV valve check your timing. It also might not be a bad idea if you have a full-length exhaust maybe not in good shape to possibly put a set of good free flowing headers on there. also rebuild your carburetor and make sure you have it dialed just right.. Also don't forget to change your cap and rotor
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ben Wright 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 2
总计 146
