Battery light on but battery tested ok
The light goes out after the 5 minutes driving?
The "Battery Light" really is telling you the electic power to run the auto is coming from the battery and not the alternator. Check that.
这个答案有帮助吗?
I have th3e same problem. The battery tests at 12.6 V and alternator tests at 15+ volts at the battery posts.
crowder451, if your getting 15+ volts when warm, that is pretty high and regulator may be faulty, check the attached link for good info. and trouble shooting charging system.
这个答案有帮助吗?
My light stays on for at least 5 mins when i slow down the light goes out..what could it be
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 9
总计 6,055
1条评论
Thanks , it was helpful!
由 Bill 完成的
