跳转到主内容
4th Generation Apple AirPort Extreme Base Station (Model Number A1354)
18 个问题 查看全部
How to change country code?
Hello
I have a MC340LL/A model and have to use it in Europe
airport utility in the option network show only US and america country ...how to correct this in order to respect local legislation as the AEBS is supposed to be compliant to world regions regulations ?
Thanks for any hints
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hey @Philippe P, did you solve this problem of change firmware region on Apple AirPort using the Java solution commented by @mayer ?
I saw the specifications of the Java software, and I believe this program only helps to access the equipment without the AirPort Utility, with no advance (plus) settings, like change the network country firmware (region).
Best regards!
完成的
添加一条评论
2个答案
已选择的解决方案
Here's a Java-based configurator for the Apple AirPort Base Station and Lucent RG-1000 wireless access points. It should run on any platform with a Java 1.2-compliant runtime environment installed, permitting the configuration of a base station from any host.
http://gicl.cs.drexel.edu/people/sevy/ai...
这个答案有帮助吗?
得分 2
1条评论:
完成的
添加一条评论
This is a firmware-based setting that I don't believe you can change; it's a fairly common request but I've never seen a solution.
See e.g.:
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Philippe P 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 9
过去 30 天: 10
总计 13,205
