跳转到主内容
關於自行維修iPhone所需的任何一切,從最新的iPhone15產品線,一路追溯到2007年所發布的初代iPhone。iFixit有著每一台iPhone維修指南、拆解資訊,並且完全免費,還有全宇宙最好的更換配件、工具、技巧!
36478 个问题 查看全部
How do you remove all information
giving old iphone to daughter and want to remove all information and the newest software update that I shouldn't have updated
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
1条评论
Hello, you can try using the iPhone Data Wiper, which is an all-in-one data erased software, providing the most reliable and safe wiping solutions for iOS user to permanently wipe all data including pictures, videos, call history, SMS, web browsing history, settings and more, remove junk files from iPhone, iPad & iPod touch. What’s more, it does this using the US Military method of destroying data, ensure any data delete from your iPhone is unrecoverable, furthest protect your personal information’ safe. In addition, the program fully compatible with iOS 9.2, and support iPhone 6s & iPhone 6s Plus, as well as iPad and iPod touch.
Read the details from: http://www.recover-iphone-ios-8.com/dele...
完成的
添加一条评论
4个答案
已选择的解决方案
to remove new update you'll have to download the old iphone software. google ipsw 3.1.2 or whichever it is that you want. put phone in recovery, plugged in to itunes and when itunes says it has found a phone in recovery mode you'll need to press alt and click on restore (in itunes)(sorry this is for a mac, don't know the exact path for windows but it's probably on the site you get the ipsw from) then select ipsw you want to restore to. bob's your uncle, iphone restored
you may already have an old ipsw in your itunes library and can use that instead
ihackintosh is a good site for help on software problems
这个答案有帮助吗?
得分 2
添加一条评论
最有帮助的答案
Hi Lisa,
Do the following on the IPHONE:
  1. go to SETTINGS
  2. touch GENERAL
  3. scroll all the way to the bottom
  4. touch RESET
  5. touch ERASE ALL CONTENT and SETTINGS
  6. while you are add it, Tap on all the RESET options, just to make sure
  7. lastly do what Mr. Essen wrote, just to Triple check all info is gone
Or if you have Mobile Me or you know someone who does, have them do a remote wipe to destroy all info on you IPHONE, IPOD, IPAD.
good luck
GqMarti
这个答案有帮助吗?
得分 3
1条评论:
thanks works
完成的
添加一条评论
iTunes has tools for managing your phone. If you plug it into a fresh copy of iTunes and do a restore, it should remove everything. There might be an option to do a restore without a re-sync of your current data.
To un-update it is probably trickier. I have only done this with an iPod, never an iPhone. You might have to re-format it as a drive, then find someone with an older copy of iTunes to do a restore with.
这个答案有帮助吗?
得分 1
添加一条评论
Whether you are planning to give away your old iDevice to a friend or relative, donate to charity; you never know where your old device will end up. Don’t leave your personal information vulnerable to identify thieves; ensure it’s not recoverable by permanently wiping the iDevice with EafeEraser – think of it like a digital shredder.
Sync your iPhone to iTunes or store your iPhone can help you erase your iPhone data.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Lisa Kennedy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 3,938
