跳转到主内容
The Xbox 360 is the second game console made by Microsoft, and was released November 22, 2005.
428 个问题 查看全部
Why wont my 360 read discs?
I tripped over the ethernet cord attached to my 360 and it took a 3-foot dive. Now it wont read discs. Everything else seems to work fine and I can hear the discs start to spin, but after about two seconds it stops and the dashboard says open tray. I would rather avoid opening it up but if thats what it takes then so be it. Any help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 -1
添加一条评论
1个答案
最有帮助的答案
The laser most likely is jammed in the back of the drive. This is a common thing we see when the systems are dropped. Just open up the system and realign the drive. While you are in there, give it a good cleaning. The drive should be dust free. The railing that the laser guides on, make sure that it is clean and well lubricated with gear grease of some sort.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Timothy 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 0
总计 1,796
