跳转到主内容
Released June 2012 / Core i7 processor with Turbo Boost / Up to 1 GB GDDR5 Video RAM
597 个问题 查看全部
问题已关闭
Fan connector broken off motherboard, is fan needed for function?
The computer in question is a 2012 13" macbook pro with the i5. I understand the fan plays a role in cooling the hardware, but will the laptop itself check for it? In theory I can wire said fan up to any old power source and just let it run full tilt and the computer wont throw any errors at me in regards to a missing component?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
A lot of computes will check for a working fan and throw an error if it doesn't find one, or it's not spinning. Unfortunately the Macbook pro that you have was not designed to work without a running fan and will most likely overheat fairly quickly and shut down again. I would not recommend running the hardware without a fan as the Processor is not designed to be passively cooled like the new Macbook.
这个答案有帮助吗?
得分 2
添加一条评论
I haven't worked with Macs extensively in a few years; but, I'm confident in saying that It will function normally without the fan. The system will check all components at boot-up and generally flag you of a component that is not operational. In terms of shutting down, it would happen automatically if the internal temperature exceeds its designated threshold.
这个答案有帮助吗?
得分 0
1条评论:
Tell you what, since it's getting cold try disconnecting your auto fan and tell us afterward if you engine overheats and burns the engine up, then answer this question. Or don't you want to risk it on your machine?
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 3
过去 30 天: 6
总计 77
