How to clear error code dU?
washer beeps continuously, lid switch replaced, how do I clear error code dU? The book directions do not work.
Unplug it for five minutes to allow a reset.
UPDATE
The DU code indicates that the door is unlocked.
Cause 1
Door Lock Motor and Switch Assembly
The door lock secures the washer door shut during operation. Once the washer door is closed, the washer can begin operating. If the door lock is defective, the washer door will not latch properly. The door lock can fail either mechanically or electrically. Inspect the door lock for damage. If the door lock is damaged or does not latch properly, replace it. To determine if the door lock has failed electrically, use a multimeter to test each of the door lock switches for continuity. If one of the switches does not have continuity, replace the switch.
Cause 2
Door Lock
The door lock assembly might be defective. Inspect the door lock for damage. If the door lock is damaged, replace it.
Cause 3
Door Latch
The door latch assembly might be defective. Inspect the door latch for damage. If the door latch is damaged, replace it.
这个答案有帮助吗?
No, I tried that already. I actually, had it unplug for 1 hour.
I recently replaced the lid switch however, the clicking and constant beeping is still happening. I think I need to replace the complete board, what do you think?
Sarvarie, were you able to determine the cause? I going through the same thing right now.
Had same problem, turned out I had over loaded machine, works fine now
Alguien pudo solucionarlo?
Tenia el código du y remplace el seguro pero continua con el mismo codigo du
Had the same problem. I unplugged the washer for 5 minutes, then replugged and pressed on start and stop at the same time and it unlocked.
这个答案有帮助吗?
过去 24 小时: 0
过去 7 天: 9
过去 30 天: 53
总计 16,366
