跳转到主内容
索尼电脑娱乐发布的电视游戏主机。于2013年1月20日发布,2013年11月15日上市。
ps4 wont use update on usb
I replaced the motherboard/optical drive on my ps4 and now its asking for system update using a usb for version 3.00 or later. I formatted my usb for FAT32 and downloaded the update from the plastation.com website and put it in the file format PS4->UPDATE->PS4UPDATE.PUP
it gave error code (CE-35952-4)
this didn''t work. Then I tried the exfat format with the same file path, and that did not fix the problem either. Both were attempted in safe mode, I have tried all of the other options from the safe mode menu and still the system will not load properly.
Please help and thank you for doing so.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 13
16条评论
I finally got it to update after using your advice and a 2 gig usb. For whatever reason the ps4 wont update using a usb with greater than 4kb block size. Go figure. Thank you for your help!
完成的
Great news! I'm glad you got it working!
完成的
If replacing a HDD into the PS4, as TronicsFix stated, do not download the top update file. You need to download the file under System Software Tab at the bottom of the page (~800 mbs). Kept experiencing the same problem as the PS4 said get latest update file, which I already had in my FAT32 formatted usb drive. Thank you TronicsFix
完成的
This was the REAL fix...what a life saver... she's awesome☺
https://youtu.be/S6CVYhBYMDw
完成的
I just got myself a new 2tb hard drive for my PlayStation 4 and I got a USB flash drive that's been formatted so I could download the update. I didn't download the first link at the top of the page but I downloaded the other one that's 800mb and made a file PS4->UPDATE-> "PS4UPDATE.PUP" and out my PS4 in safe mode and tried initializing PS4 software and it says update not found! Need help ASAP!
完成的
显示更多的11条评论
添加一条评论
12个答案
已选择的解决方案
There is a good chance that you have the wrong update file loaded onto your drive. When you are on Sony's website the first one you come to is not the right file (It's for the most current UPDATE...you need the entire system software)...the file you need is located near the bottom of the page. When you get close to the bottom of the page you'll see this: "Perform a New Installation of the System Software"
That's the file that you need. Just be sure to reformat your drive and follow the rest of the instructions to a T.
I hope this helps. Post back here if you still need more help.
Good luck!
这个答案有帮助吗?
得分 22
11条评论:
I've done all of that and I still get the same error
完成的
thanks so much. after OEM hard drive fail, I installed a 2T internal. I kept downloading the wrong file. As soon as I grabbed the 900K file for full install I was back in business. THANKS!
完成的
I created an account just to thank you for this post. You're the best!
完成的
I am unable to see a perform new installation tab on the PlayStation website as I’m having the same trouble, any advice?
完成的
"Perform a New Installation of the System Software" This is not available on their site,even though i click reinstallation,it brings me to link of just update
完成的
显示更多的6条评论
添加一条评论
I used a 2 Gb Usb rather than an 8Gb one and it worked fine thanks guys
这个答案有帮助吗?
得分 4
4条评论:
Great news! I'm glad you got it working.
完成的
After doing this mine goes to system software update screen and shoots error code Su-30679-5 any ideas?
完成的
does the usb have to be a 3.0 usb
完成的
Download PS4 reinstallation file im using this file to download. but usually when i dwnload something it shows on btm left of my comp,this case nothing. usb is formatted to exfat or whatever.i never had to do this stuff,and now i cant figure out.
完成的
添加一条评论
I finally got mine to work after hours of try and looking up stuff online with no luck. I renamed the file "PS4UPDATE.PUP" before I put it in the "UPDATE" file (usually I was naming it after placing it in the file). I didn't delete the old file that was in there. A message came up that I was downloading a duplicate file named "PS4UPDATE.PUP.PUP" So my computer already applied the .PUP so I didn't need to add it to the file name. So I removed the .PUP and just put in "PS4UPDATE" and to finally worked. Hope this helps.
这个答案有帮助吗?
得分 3
3条评论:
I just tried that and got "Cannot find update file" :-(
完成的
You just saved me! Spent wayyyy too long trying to figure this out and all I had to do was remove the .PUP lol
完成的
Omg it just worked for me to wow so glad i read this to remove the .pup. Thank you
完成的
添加一条评论
formatting to FAT32 and not EXFAT plus downloading the 980MB file again did the trick for me ((:
这个答案有帮助吗?
得分 1
1条评论:
where'd you find that file at?
完成的
添加一条评论
Ok so…. I had a power outage the other day my ps4 was on. I didnt want to turn it on again because of the possibility that it could go out again. So the next day I go to turn it on and it says that I need to install the update file via usb, disc or internet. I booted it in safe mode and tried internet (with lan cable). ,,update file 7.51 available” I press it to update. First it downloaded the update, then it started applying it. After that it restarted and checked my HDD again and I was at the beggining. Did it a couple more times. Tried with USB (FAT32 , 4 GB storage abd everything named and downloaded corectly) the ps4 got it, downloaded the update, applied it and after restart - nothing. Back at the beggining, checked the HDD and it just doesnt want to update. Says update complete and when it restarts it doesnt want to boot. I really dont want to factory reset it, because I have so many clips and other files that I want to keep. Is it possible to update it without wiping the whole HDD. I need answers. Thank you beforehand.
这个答案有帮助吗?
得分 1
1条评论:
have you fixed it cos i have the exact same issue
完成的
添加一条评论
Wat kind USB do u need im having same problem I've got 32 gig USB still not working help plz
这个答案有帮助吗?
得分 0
1条评论:
Be sure to Format your USB. If you have used it for anything else other than this update file, you will need to do that.
完成的
添加一条评论
can i use a 4gb? cause I've tried a 32, 16 and under a 1gb but the first two didnt work and the last one had to little storage.
这个答案有帮助吗?
得分 0
1条评论:
I tried a USB drive with 2 GB and mine doesn't get recognized by the PS4 either. Does the flash drive need to be a specific USB version? I believe this one is 2.0, but I can't be sure.
完成的
添加一条评论
I’m having a issue used a 2gb usb in exfat and also fat 32 downloaded the full system software update file it starts and completes the loading bar then says file corrupt right at the end I dnt no why I’m doin wrong any answers ?
这个答案有帮助吗?
得分 0
添加一条评论
I've tried with a 16gb and it won't load…&&^& Playstation…I'm going back to Xbox
这个答案有帮助吗?
得分 0
添加一条评论
Hey guys, got 16gb flash drive, did as recommended from sony;s web sited. but it throws the same error Cannot find the update file. . is it hdd issue? I checked and showing 100% healthy
这个答案有帮助吗?
得分 0
添加一条评论
Hi ifixit
Trying to find not sure if it update file or system software, installing a new 2TB internal hd in my ps4. Been to the playstation website to find it and go to the bottom and it not there please help here it the website I went to playstation.com or does it have another name for the proper downloads
Ty suziewong
这个答案有帮助吗?
得分 0
1条评论:
Hey Guys My PS4 hard drive got Faulty so I Bought a New One N Replaced it but now I am struggling with Reinstalling a System Software It keeps on saying “Corrupted Data" I've Tried Almost all options still Getting the Same Error Code I Need Help 😔 haven't Played my anything since the year Started
完成的
添加一条评论
So when doing the flash drive format to fat32 or exfat than create a folder PS4 caps and click into that and create folder UPDATE all caps and than put update in that folder and it should work. Good luck everyone
这个答案有帮助吗?
得分 0
1条评论:
new hard drive and when installing i got this : ( The update file cannot de used ) . any help !
完成的
添加一条评论
添加你的答案
unitunitglue 将永远感激不已
浏览统计数据:
过去 24 小时: 16
过去 7 天: 140
过去 30 天: 600
总计 163,235
