跳转到主内容
Repair and disassembly guides for GE Microwave ovens.
door won't open when button pressed
I have a GE microwave/oven wall unit and the door doesn't open until 5-10 seconds after cooking or after pressing open button. There is no outside handle. I don't want to replace due to cost and installation in wall.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
最有帮助的答案
Cause 1
Open Lever
Inspect the open lever for damage. If the open lever is broken or damaged, replace it.
Parts
Cause 2
Door Spring
Inspect the door spring for damage. If the door spring is broken, replace it.
Parts
Cause 3
Door Latch
Inspect the door latch for damage. If the door latch is broken, replace it.
这个答案有帮助吗?
得分 2
2条评论:
Our door does not open at all - so how would you be able to check for anything on the inside?
完成的
Ours is newly purchased and has this issue from the beginning. I have to push the button 2 or 3 times to open it when no food inside. After cooking, it is easy to open.
完成的
添加一条评论
Check the latch that is inside as it might be dirty. This would cause it to open more slowly than expected. You might have a broken spring where the latch holds the door making it not move enough to release the door.
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
Okcphinfan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 3,363
