跳转到主内容
The HP Split x2 is a 13" hybrid tablet/laptop combination was sold in mid-2013. The HP split is easily identified by its pull apart design.
Why is my device not charging?
My device will not charge when it is plugged in. The battery icon on my laptop shows low battery and not charging. Why is my laptop not charging?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 5
添加一条评论
2个答案
已选择的解决方案
There are several possible causes of your laptop not charging. The most common are:
  • A loose power cable. Make sure that the power cable from the wall to the charger is completely inserted.
  • A bent or broken DC plug pin. Check inside of the DC plug and make sure that the pin is not damaged.
  • A problem with the charger. If the charger brick is cold to the the touch despite being plugged in, the charger may be faulty.
You may find more information on the HP Split x2 troubleshooting page.
这个答案有帮助吗?
得分 2
添加一条评论
Mine wont charge either..UNLESS i push in the charger its not the charger in the cpu plug jack just push it it to the jack and lay it against something to keep it in
这个答案有帮助吗?
得分 0
1条评论:
Hi @kandycub ,
What is the full model number of your laptop?
From your description it does seem as though there is a problem with the laptop's power port.
完成的
添加一条评论
添加你的答案
Matthew Jordan 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 10
总计 8,800
