跳转到主内容
Second generation of the Fairphone, made by the social enterprise with the same name. Released in December 2015. Model number: FP2-XCVR
74 个问题 查看全部
Is the Fairphone2 aptX-capable?
Out of the components you have identified in the Fairphone 2, can you tell if the FP2 supports aptX (bluetooth codec)?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Hi Matt,
if you are referring to the ability to stream audio via Bluetooth to a sound system it is a YES.
I have tried it with a Bose SoundLink III and it worked.
Regards
这个答案有帮助吗?
得分 1
添加一条评论
Dear Matt,
the best way to get a right answer in short time is to pose your question directly to the fairphone team at https://www.fairphone.com/contact-us/
Good luck
Markus Scheuermann
这个答案有帮助吗?
得分 0
添加一条评论
well considering it has many of the same guts as the htc one m8 it shoud in theory be capable on a hardware level
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matt Kelp 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 10
总计 1,019
