跳转到主内容
Model A1311 / Mid 2011 / 2.5 & 2.7 GHz Core i5 or 2.8 GHz Core i7 Processor
Upgraded to El Capitain stuck on past splash page
I just upgraded an iMac to El Capitain and it stuck on the splach page. It would boot but just get stuck at the splash screen, loading bar would go all the way but then just get stuck,tried booting to safemode , ran disk util and to get to the terminal and played around in there nothing. Anyway decided to reinstall and its no joy stuck in the same spot. so I shut it down and decide to take a break from it . come back after 2 hours and figure id give it another try start the computer and it boots fine. Can anyone tell me whats going on . I dont want to return the machine till I know its going to work fine Can some of you Mac gurus give a hand here
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
5条评论
Jim, you know the drill - last four figures.....
完成的
the last four digits are DHUF
完成的
Look again on the bottom of your stand, those numbers do not work.
完成的
sorry need my glasses its a j not a u DHJF
完成的
Apple iMac "Core i5" 2.5 21.5-Inch (Mid-2011) Specs
Identifiers: Mid-2011 - MC309LL/A - iMac12,1 - A1311 - 2428
完成的
添加一条评论
1个答案
已选择的解决方案
Did you change the hard drive or anything else? Seagate 1 TB hard drive?
Almost as useful as a T8: https://www.micromat.com/products/techto...
这个答案有帮助吗?
得分 3
7条评论:
When the original update was don it was on a NIS it was then unmounted and move to do further testing it booted without the NIS so remounted it and it seems to be running fine now so I think it was the NIS . Im gonna check the logs now that its booted and see if thats the reason
完成的
What's a NIS?
完成的
Thanks for the help
完成的
NIS is network information service a client–server directory service protocol for distributing system configuration data
完成的
How's that working for you? Never used one, sounds like PC or UNIX to me.
完成的
显示更多的2条评论
添加一条评论
添加你的答案
Jimfixer 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 22
总计 588
