跳转到主内容
加入维修社区 - 创建账户
TDK Trek Max 是一款配备蓝牙功能的便携式无线音箱。内置麦克风让音箱可以通过蓝牙或有线连接,为任何已配对设备提供免提通话功能。其配备的辅助接口和 USB 接口使其能够兼容几乎所有设备。
Why won't my speaker turn on?
I have had the device plugged in all day and it still won't turn on. My brother has the same speaker and uses my charger so I know that is not the problem. I'm thinking the battery is dead or maybe the charge port is malfunctioning. What can I do?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
I saw you mentioned the sound was low on this speaker in another thread, did you get the power issue resolved then?
由完成的
添加一条评论
3个答案
最有帮助的答案
If the speaker is not turning on after a full charge it could be suffering from a battery malfunction. Follow our guide on battery replacement to fix this issue.
这个答案有帮助吗?
得分 1
添加一条评论
Trek max will work even without a battery connected. (power supply must be connected). I have one that works only when fully charged for a short time unless charger plugged in. This indicates a problem with battery voltage sensor. Same battery works fine in another unit. Your problem may be a worse case of this. I suggest Remove battery and test it.
这个答案有帮助吗?
得分 0
1条评论:
My Trek Max A34 will not charge. I thought it was the battery so I boughf a new one. That won’t charge either. Only way Trek Max will work is plugged in. How do I fix this issue?
由完成的
添加一条评论
Jag får inget ljud i högtalarna
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rebecca 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 5
过去 30 天: 13
总计 4,318
