跳转到主内容
LCD Screen goes black from time to time when moved, why?
Okay, so I honestly have a couple of problems with my laptop after having it for almost 4 yrs now. But my main concern now is my screen. Idk if it's because the hinges are loose and needs to be tightened (Which obviously the right side is), or if it's something else but, whenever i move my laptop a certain way, the screen goes black. Then i have to move it again for it to be working again normally. It seems as if something is loose but don't know what it could be. Any help?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 5
1条评论
So if it's the inverter cable, how do I fix it? Do I need to buy a new one? I figure It was probably just lose but if it's broken then I have to get a new one right? Are the instructions to fix this problem the same steps as the one mayer gave me? Just one to be in the safe side before I go and do anything. Thanks!
完成的
添加一条评论
2个答案
最有帮助的答案
The most likely problem is a worn display data cable, especially since you're having hinge problems. Here's how to replace it: MacBook Pro 15" Core 2 Duo Model A1211 Display Data Cable Replacement
这个答案有帮助吗?
得分 3
3条评论:
完成的
Sorry but the issue has nothing to do with the display/data cable (LVDS cable). The culprit is probably the inverter cable that bring power to the backlight lamp in the LCD panel.
完成的
Here's how to replace the inverter cable: MacBook Pro 15" Core 2 Duo Model A1211 Inverter/Camera Cable Replacement
If you can still see the desktop dimly from an angle when it goes black then Lemerise is correct. If you can't see it at all, then I'm probably right.
完成的
添加一条评论
Hi,
from my experience it is rather the wiring on the left side, which connects to the inverter. One cable of it might be almost torn or torn already is therefore causing the backlight going on/off depending on the screen angle.
这个答案有帮助吗?
得分 2
1条评论:
good answer +
完成的
添加一条评论
添加你的答案
SorceEdea 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 11
过去 30 天: 14
总计 30,994
