跳转到主内容
The TDK Life on Record A33 is a weatherproof Bluetooth speaker. It was released in 2012 and is now discontinued.
Why won't my TDK Life on Record A33 charge?
I'm trying to charge the speakers, but when I plug in the charger nothing happens. Is there anything I can do to get it charging?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
1条评论
My A73 wouldn't charge and there is another connector on the battery compartment
完成的
添加一条评论
2个答案
已选择的解决方案
Hi,
Ensure that the main power switch (located on the side under the flap is in the OFF position, when trying to charge the unit.
If it is and you still get no charging indication with the charger connected to a known working power outlet try the following:
Connect another known working 12V DC output charger (specs are on the charger) with the correct size plug (centre is the + pin - most are but be aware). If the light comes on your 1st charger is faulty. If not you either have a faulty battery or a faulty charging circuit in the speaker .
If the speakers work when connected to the charger then the problem is most likely that the battery has failed. They do have a life expectancy. Here is a link for a replacement battery http://support.tdkperformance.com/articl...
这个答案有帮助吗?
得分 4
7条评论:
Hi,
Thank you for the info. The main power switch was off and I don't have another charger. I think I'm going to replace the battery.
完成的
Hey I have a similar problem. At first though my speaker would be on and working but it just wouldnt charge. Eventually the battery died and i haven't been able to charge it since.
完成的
Nate Kristich sounds like a bad battery.
完成的
my battery went bad as well - new battery similar price to replacing the whole thing
完成的
How to charges my tdk speaker a33
Is turn of or turn on to recharges
完成的
显示更多的2条评论
添加一条评论
If your device isn't charging, it might be because you need to turn off your device. There might also be problems with your AC adapter or your battery. The troubleshooting guide for the A33 not charging can be found here
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Matthew Phou 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 25
总计 11,773
