跳转到主内容
Announced on October 16, 2014, the iPad Air 2 is a thinner successor to the iPad Air.
450 个问题 查看全部
Screen adhesive not sticking properly.
Hello,
I ran a repair on my iPad air 2. I replaced the digitizer and front glass pane. Is there any special way of ensuring that the adhesive sticks to the iPad? I have had !&&* making sure that the glass sticks properly.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
已选择的解决方案
I use a heat gun on low setting, to gently heat the adhesive on both iPads and screen replacement on MacBooks. Heat Gun
Heat Gun图片
产品
Heat Gun
$24.99
这个答案有帮助吗?
得分 2
3条评论:
what would you say the best way to remove old adhesive to be?
完成的
GooGone works for me.
完成的
Go to your local Store and grab some Nail Polish Remover,Q-tips and a napkin.Remove the cap from the NPR and fill it halfway.Now dip the Q-tip in the NPR and then dab it lightly on the napkin once and rub it on the adhesive along THE OUTER EDGES of the iPad while being careful not to allow any of NPR to touch or drip on ANY other components including the LCD.Wait 3 minutes before scraping the adhesive off and now you should find it WAY EASIER AND FASTER to remove the old adhesive.
*Note*
I find it best to use one of the blue or green plastic pry tools that usually come with most screen repair kits as it will do significantly less damage then a metal object if you slip off of the target area.
完成的
添加一条评论
添加你的答案
zachwalls 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 1
总计 633
