跳转到主内容
An easy to use home Espresso machine created by Saeco and rebranded for Starbucks. This machine is excellent for every day espresso drinkers and has an excellent build and product life.
138 个问题 查看全部
My barista does not suck the water up into machine
Dear sirs,
Is there a place that repairs these barista espressor makers? as I have taken my apart from the back to make sure the two plastic tubing lines are clear, I have poke a small nail into the opening where the tubes connect to make sure they weren't plugged, but the pump part of the expresso maker does not seem to have enough suction to pull the water up into the machine, and I don't know what else to do to fix it
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
3个答案
已选择的解决方案
Try forcing water into the intake tube with the pump running; a turkey baster or nose/ear bulb works well. If the pump still will not suck water on it's own it may be partially plugged with calcium, if you haven't been regularly descaling. Seattle Coffee Gear can repair these machines and gives free repair estimates.
这个答案有帮助吗?
得分 4
5条评论:
+ How do you descale? Do you use LimeAway?
完成的
I would use either Dezcal or Durgol, they're designed specifically for espresso machines.
完成的
Thanks
完成的
I thought my machine was done for after putting it in the basement for two years without use. It had no suction power at all. I read Henry H's note above and tried the turkey baster. It worked right away. Then I descaled it with my Brew Right cleaner and have been making lattes again. Thank you Henry!!!!!
完成的
Great idea. It took a few tries of squirting the water up the intake hose but now it works splendidly. Thank you.
完成的
添加一条评论
We tried everything to unclog the water line. We used a turkey injector a couple of times and it pushed whatever was clogged thru, and now it is working great. We were going to try the turkey baster, but the end was too big to fit in the hose.
I didn't know to use a descaler, but will buy some and use it frequently now.
这个答案有帮助吗?
得分 0
添加一条评论
https://youtu.be/xZIqO-i5kQg
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Christine Woodward 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 17
过去 30 天: 125
总计 19,008
