跳转到主内容
型号A1288,闪存容量:8、16及32GB
Why doesn't my replacement digitizer stay on?
My replacement digitizer sticks up above the iPod and won't stay on. Any suggestions? Help would be greatly appreciated.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
I would say you never connected it fully or properly
完成的
Do you know how to connect it fully and properly? Thanks.
完成的
添加一条评论
3个答案
最有帮助的答案
you should buy it in one
这个答案有帮助吗?
得分 1
1条评论:
it is so much easier +
完成的
添加一条评论
NOTE! Always remember, this is for reference only. If you are to perform this, make sure that you understand that you are doing this "at your own risk". I am not liable for any damages, injuries and other bad things that may arise from following this.
|| IF YOU DO NOT UNDERSTAND OR UNWILLING TO UNDERSTAND ||
|| THE TERMS AFOREMENTIONED, YOU SHOULD NOT ||
|| PERFORM THIS. RATHER, HAVE THE UNIT SENT TO ||
|| APPLE FOR REPAIR.||
Putting the digitizer back on is a lot easier than removing it. All you have to do is reconnect the digitizer ribbon end back to the it's socket on the green board. Be careful not to pull on the ribbon too much, as you may and up with a broken digitizer again. The proper position of the cable can be seen in the disassembly guide. After finishing the connection, it's time to snap the plastic bezzel of your digitizer back into the iPod touch frame. Place the digitizer ontop of your iPod touch and align it with the body. Refer on the manual for the placement of clips, so that you know where to press on the digitizer to clip it in place. After placing the digitizer back, apply some pressure and run your finger on the digitizer edges so as to ensure that the clips are locked securely.
这个答案有帮助吗?
得分 1
添加一条评论
also second gen and 3rd gen digitizer cables connectors are different size you have to have the correct one
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Noah Epstein 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 2
总计 5,421
