跳转到主内容
Repair and disassembly guides for all revisions of the Apple TV media player and streaming box.
138 个问题 查看全部
How can I convert the hard drive from ATA IDE to SATA?
Howdy everyone! I'm getting an Apple TV from eBay, and I'm a little bummed that it uses the old (40GB) ATA IDE hard drive interface, and I'd rather use a 120GB SATA that I have lying around not doing anything. I've looked for connectors or cables that would do the trick, but I don't think I've found one suitable. I located this: http://eshop.macsales.com/item/Addonics/... on OtherWorldComputing, but it seems that it needs to be plugged in to work! I just need something that I can conceal in the Apple TV that you would never know was inside.
Anyone got any ideas? Is there a ribbon cable that would go straight from the logic board to an SATA drive?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
3个答案
已选择的解决方案
It looks like you've found the best answer I've seen for this problem. There is nothing that will convert directly like just a ribbon cable. You'd be much better off getting the correct type of drive because the degradation in performance may be unacceptable.
这个答案有帮助吗?
得分 4
7条评论:
Okay. I just hate the costs of the old ATA drives. They're irrationally expensive. haha. Thank you so much for your help. It'll be a project. :)
完成的
I just bought one at Best Buy (a 500 GB) for $74.50 two days ago.
完成的
No way!? The laptop size?
完成的
Wow, that must have been a Super Sale or something, because I just scoured Best Buy's website and the only PATA hard drives they have are good deals indeed, but far smaller and therefore far more expensive than the SATA ones. Did you buy that one online or in the store?
完成的
完成的
显示更多的2条评论
添加一条评论
I found a nifty IDE to Sata adapter at Microcenter. It was cheap and so far I haven't heard any complaints about the machine's performance. The adapter actually connected right to the back of the drive and needed no external power supply. It looks like a tiny logic board with the Sata and IDE connectors on both sides. Check on Microcenter.com
这个答案有帮助吗?
得分 2
1条评论:
Howdy! Yeah, this was a great one, too. I found it after I made this post:
http://usb.brando.com/2-5-ide-male-to-sa...
I'll look for yours though. :) Thanks!
完成的
添加一条评论
Hi guys, sorry for the moment of stupidity but I seem to be having a bit of an issue. I bought the adapter posted by TommyJames337 above. I have the SATA HD. The problem I'm having though is that the IDE cable that comes with the Apple TV is 44-pinhole but with the 1 pinhole blocked. The adapter is a full 44-pin adapter. Ergo, 44 pins won't plug into a 43 hole IDE cable. The other end of the cable is a full 44-pinhole connector, but that plugs into the Logic Board. What the heck should I use for an IDE cable to connect the two?
Suggestions would be greatly appreciated!
这个答案有帮助吗?
得分 0
1条评论:
Please start a new question. Thanks
完成的
添加一条评论
添加你的答案
TommyJames337 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 13
总计 23,492
