跳转到主内容
戴尔台式机的维修指南。
448 个问题 查看全部
问题已关闭
Clean PC Memory Stick contacts?
Hi,
Inherited an older Dell PC. After checking it over powered on and the lights and beeps told me there was a memory problem.
Removed the 2 Memory Sticks and examined each one. Noticed there was some dirty contacts.
Googled and found "you can at least clean the contacts on the expansion cards and memory modules directly. Some people use a soft, clean rubber eraser for cleaning contacts, but we think the best tool for that purpose is a fresh dollar bill, which has just the right abrasiveness to clean the contacts without damaging them. Simply rub the dollar bill briskly against the contacts, as shown in Figure 3-16."
Computer System Cleaning
Also found "If there is visible foreign matter on the contacts, clean it off
with a solvent."
http://help.lockergnome.com/windows/Clea...
Most recommend isopropyl alcohol.
Appreciate comments from others that have solved this problem.
Thanks
Ken
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
最有帮助的答案
I recommend isopropyl alcohol. I've used it on multiple dirty computer components with no negative effects. Not only does it not damage components due to its low water content, but it cleans very easily and is readily available at almost any drugstore.
I suggest 90%+ but 70% works fine in a pinch.
Edit: Use a Q-tip or fine cloth to apply it
这个答案有帮助吗?
得分 1
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 8
总计 454
