跳转到主内容
First released in January of 2014, the Pebble Steel is a steel-bodied Smartwatch from Pebble Technology Corporation.
7 个问题 查看全部
My Pebble steel isn't vibrating when I receive a new notification
My Pebble Steel watch is not vibrating when I receive a new notification. I can still see when I get a notification because it pops up on the screen but I don't feel the vibration. I have made sure that the settings on my phone and watch are both set to vibrate for a new notification. What else can I do?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 4
1条评论
that fixed the problem. thanx.
完成的
添加一条评论
6个答案
已选择的解决方案
Also, try visiting the troubleshooting page for more help.
这个答案有帮助吗?
得分 6
添加一条评论
最有帮助的答案
Mine was in Quiet Mode. You can change this in the settings. You can also change this by holding down the button on the left side of the watch while at the watch face.
这个答案有帮助吗?
得分 18
12条评论:
Worked for me, i feel so stupid now
完成的
Mine was not working either, Supid #2! Thanks!!!
完成的
Wow! Thanks! *face palm*
完成的
Add me to the dummy list! Thanks for the help
完成的
Not working. Howwwee
完成的
显示更多的7条评论
添加一条评论
Try resetting the watch.
这个答案有帮助吗?
得分 3
3条评论:
I reset it and it only vibrates on phone calls.
完成的
I reset mine nothing, no vibrating at all. I'll try again.
完成的
Though it works, feels over kill. Try the quiet mode
完成的
添加一条评论
No solution worked. No vibration at all even after hard reset
这个答案有帮助吗?
得分 1
添加一条评论
My pebble steel started to vibrate again, after android wear app was removed
这个答案有帮助吗?
得分 0
2条评论:
I had same problem after installing Android Wear. I took 'belt and braces' approach and deleted AW app and also did a factory reset on the watch and signed in with a new account to make sure I really was back to 'factory settings'. I chose this boots-and-all approach as I had previously also installed a new watchface (Beacon) which screwed the watrch up completely and caused it to reboot at random times and I wanted to make sure I had totally got rid of it.
完成的
Thanks. I m on the top of the dummy list!!
完成的
添加一条评论
Just discovered this:
Notifications will appear, but not vibrate, when the Pebble Time is charging.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Orlandria Heggs 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 6
过去 30 天: 14
总计 15,574
