跳转到主内容
问题已关闭
Blue screen upon boot
The Fault: The Laptop powers on, glitches and then turns off again, sometimes with a blue screen and can't boot into the operating system and continues to reboot, I'm not sure what's wrong with it! Wonder why a blue screen? Does anyone know why?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
It is an issue with your gpu it is coming partially unsoldered from your mother board
这个答案有帮助吗?
得分 0
添加一条评论
You May need to reinstall the operating system, but im guessing your having bad incompatible startup software install try doing this first.
Shut down your Mac and wait 10 seconds.
Press the power button.
Immediately after you hear the startup tone, hold down the Shift key.
You should press the Shift key as soon as possible after you hear the startup tone, but not before.
Release the Shift key when you see the gray Apple logo and progress indicator (spinning gear).
Go To System Preferences> Users & Groups >Click on Your Admin Account > Click Login items> Click The Lock On The Bottom To Make Changes> Click The Minus To Delete All Login Items. If You Cant Access This Tru Safe Mode You Will Need To Reinstall The Operating System Again.
To leave safe mode, restart the computer normally without holding down any keys during startup.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 6
总计 2,656
