跳转到主内容
问题已关闭
Ram up to 6G?
Can this computer go up to 6G of ram? If so how do I install it?
thanks,
Brian
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Hi, If you would pick your Model MBP from the chart in my link and let us know how much memory you need we will link you to installation instructions. (It could be as little as 2 GB or as much as 6 GB depending on Model)
http://www.everymac.com/systems/by_capab...
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
As far as i know 3GB is the max.
这个答案有帮助吗?
得分 1
添加一条评论
A1226, I currently have 4G of Ram two 2G, but this site says that you can actually put as much as 6G of Ram on this computer by running a 4G and a 2G. My question would be, if this is true, which slot do you put the 4G chip into.
这个答案有帮助吗?
得分 1
2条评论:
Either one--1 4GB and 1 2GB
完成的
添加一条评论
I have just attempted to upgrade my MacBook pro4,1 (the lower case has been acts he'd so I can't read the model number), I have 2 x 2Gb SO-DIMM, however if I install both of them the machine doesn't boot. If I install eather stick along with one of the original 1 Gb sticks it boots. I have tried all combinations of RAM sticks in every slot... So long as there is no more than 3 Gb the machine boots.
Is there a trick to get it to work with 4 Gb (2 x 2Gb) installed?
这个答案有帮助吗?
得分 0
1条评论:
First, please start a new question. Second we need to know exactly which machine you have. Please look in the battery compartment and give us the last three figures of your serial number. Thanks
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 1
总计 4,481
