跳转到主内容
加入维修社区 - 创建账户
这是一款不锈钢 4 片式多士炉。型号位于设备底部。它仅有一个烤架高度,并配有一个可拆卸的碎屑盘。
Toaster Oven won't turn on
Why doesn't my toaster work when I turn the knob on?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
1条评论
Make sure Timer is in 'Stay On' position otherwise oven will not come on!
由完成的
添加一条评论
1个答案
已选择的解决方案
This could be a number of things.
  • Inspect the cord for any cuts or exposed wires
    • If the cord is damaged it should be replaced before anything else
  • Make sure that it is plugged in and that the outlet it is being plugged into is working
    • It can be checked by plugging in something that you know works into the same outlet and turning it on
      • If the outlet is not working, then that is probably the reason the oven will not work
  • Damaged internal wiring (This is very unlikely unless the oven has been taken apart since it left the factory)
  • Worn out heating elements or timer.
    • Unfortunately these can not be replaced because they contain welded connections
这个答案有帮助吗?
得分 0
1条评论:
How can you tell if the problem is the worn out elements, timer, or the heat controls?
由完成的
添加一条评论
添加你的答案
Alejandro Martin 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 7
过去 30 天: 29
总计 20,217
