MagSafe 2 is not charging, but keeps the power
I have macbook pro 13" early 2013 and it comes with 60w magsafe 2 power adapter. I was working normally all the time and a week ago it started to act weirdly. The green light is always on, even if its not plugged into mac and it doesn't charge the battery, only holds the power.
At first I though its my pc problem, did SMC reset but still nothing. Tried with my girlfriend pc, its the same. Its not charging at all only holds the power.
Does anyone got the same problem and what should I do with charger?
https://discussions.apple.com/servlet/Ji...
Update (10/18/2015)
https://www.dropbox.com/s/e39s5ccw3wl4xx...
Thats the results I am getting, not sure if the picture was uploaded correctly..
Is the adapter Apple or third party?
由 mayer 完成的
Mac is bought as second hand one, but as long as I know everything is original. From the state of charger it looked that it was used.
Have tried different outlets, but still the same.
What I could think of, that I am using it in Malaysia, there they British outlets with ground pin and mine is 2pin and have to use adapter to plug it in. But it happened after a month of using it here.
由 bagdonaspetras 完成的
Is there an Apple logo on the AC adapter? If not, it is third party. Here is a picture of the pin out. Use a wooden toothpick to test it the pins are fully extending, they are retractable. Test with a multimeter for correct voltages. https://en.wikipedia.org/wiki/MagSafe
由 mayer 完成的
It is original, it has logo and all the info on the sides.
The pins are working. Don't have a multimeter, but may go to the close store to check it. What are the correct voltages.
I have tried using my girlfriends 45w charger and it works. Tried to change adapter to the cord outlet, but still the same.
