跳转到主内容
The Garmin Vivoactive is a GPS smartwatch that includes sports apps for tracking activities, notifications, calories, and sleep. This watch incorporates features for both active and working environments.
Why isn’t the touchscreen working?
The screen freezes and becomes unresponsive to the touch.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 8
7条评论
this is the solve problem
هذا هو حل المشكلة
قم بتحميل هذا الروم للمطور الرائع mugurete
https://drive.google.com/open?id=0B_hRh3...
完成的
I flash this to my smart watch but touchscreen isn't working.
完成的
I left mine on the radiator for 5 min and seems to be working... for now.
完成的
It's not working because it's a $25.99 watch mine broke 2 days after I bought it.
完成的
Chris Allen, your answer is really helpful. thank you very much for your insight and wisdom.
完成的
显示更多的2条评论
添加一条评论
6个答案
已选择的解决方案
This could be a simple problem with a simple fix. First make sure the device is clean and free of dirt and dust. This is the most likely reason the touchscreen isn’t functioning properly. If the device is clean and still is unresponsive, perform a touchscreen-free factory reset of the device detailed in the troubleshooting guide. If a factory reset is unsuccessful, the screen may need to be replaced. Visit this Troubleshooting Page for help with the above and more answers.
这个答案有帮助吗?
得分 6
3条评论:
Just opened mine and none of the touch screen works
完成的
My watch screen turn white , so i dont know how to fix it
完成的
just opened mien and screen wont even work
完成的
添加一条评论
will a factory re-set remove all of the data I've already recorded?
这个答案有帮助吗?
得分 1
3条评论:
It honestly hurts how painfully stupid your comment is.
完成的
Be fair - sometimes a "factory reset" may not be all it seems. That has become a well-worn term that sometimes means what it says, and sometimes is a bit of a reboot flushing some - but not all - data. It depends on the device and what exactly the "reset" does.
完成的
If you force the watch off by holding the power button, it does not erase any data. If you hold the right button while powering it back on it will.
完成的
添加一条评论
3 day old vivoactive hr touchscreen not working?
这个答案有帮助吗?
得分 1
2条评论:
The vivoactive HR is different than the vivoactive. If the touch screen stops working on it and there is no damage to the display, it is most likely a calibration issue. Just reboot the watch by holding the left button 20 to 30 seconds or till the screen goes black. Then release the button and hold it for a second or two to turn it back on. When the watch turns back on it displays Garmin and calibrates the screen. Do not touch it while it says Garmin.
完成的
Thank you! This was so frustrating. Reset worked! Garmin did not show though.
完成的
添加一条评论
Just got mine and the touch screen stopped working
这个答案有帮助吗?
得分 1
添加一条评论
I bought an hour before 3 months. After swimming in the pool right button for more options does not work, while the left buttom and touchscreen work. What should I do?
这个答案有帮助吗?
得分 0
1条评论:
I have the same problem, could you fix it?
完成的
添加一条评论
from where can i get the spare touch screen for my broken smartwatch
这个答案有帮助吗?
得分 0
1条评论:
from where can i get replacement
完成的
添加一条评论
添加你的答案
Tessa Gunnin 将永远感激不已
浏览统计数据:
过去 24 小时: 4
过去 7 天: 26
过去 30 天: 137
总计 132,664
