跳转到主内容
Repair information and troubleshooting for Craftsman-brand riding lawnmowers.
554 个问题 查看全部
Why is my Lawntractor not starting
My Lawn tractor with Kohler Engine starts and runs for a few seconds and stops.
After many attempts it will start and run. But when I turn the engine off and want
to start the engine, same thing happen all over again. What is the problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
1条评论
Have you checked the fuel and supply line and fuel filter??
完成的
添加一条评论
2个答案
已选择的解决方案
tosatheo, Sounds like it possibly could be a problem with the gas cap vent blocked, loosen or remove gas cap and see if the mower runs better, if it does try to clean the caps vent holes or replace cap. If no better you will have to check for fuel flow to the carburetor. Remove fuel line from carb. and check for flow of gas, if equipped with fuel pump you will have to crank engine to check flow. If no gas flow the problem could be fuel tank clogging at outlet shut off valve/fuel filter,rubber fuel line collapsing/pinched or faulty pump if equipped. If you are getting good fuel flow the carburetor is probably clogged in the ports(needing cleaned/rebuilt)or if equipped with fuel shut off solenoid may be faulty/sticking. Good luck. I hope this helped you out, if so let me know by pressing the helpful button.
这个答案有帮助吗?
得分 2
添加一条评论
I would drain the gas out of the tank, and put in fresh gas. And I would add some Seafoam (https://seafoamsales.com/small-engines/) additive to the fresh gas. Then crank the engine. If it will run for just a minute with the new gas / seafoam mix in the tank, the seafoam will have the chance to clean the gunk out of the fuel system.
I had a situation just like yours - it would run a minute, then die. I put fresh gas with seafoam in the tank and cranked it. It immediately started running like new, and has been for a year now.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
tosatheo 将永远感激不已
浏览统计数据:
过去 24 小时: 3
过去 7 天: 13
过去 30 天: 34
总计 1,141
