跳转到主内容
2.2 GHz (Turbo Boost 最高可达 3.4GHz), 2.5 GHz (Turbo Boost 最高可达 3.7GHz), 或者 2.8 GHz (Turbo Boost 最高可达 4.0GHz) 四核 Intel Core i7 处理器 ,配备 6MB 共享三级缓存。
773 个问题 查看全部
问题已关闭
MacBook Pro 15" 2015 Screen Replacement
I have a Macbook Pro 15" 2015 version and I dropped my laptop and screwed up the screen, I've looked high and low for a replacement but they are in short supply. I'm curious if anyone knows if the Late 2013/2014 model screen will work with the the 2015 model.
The only one that I can find that says it is compatible is this one:
Link text
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
4个答案
已选择的解决方案
Parts for this machine are just not available yet. Your only source may be Apple. Give them a call and ask what their Flat Rate Repair charge is on it. The Flat rate may be much less than just asking them for a repair quote. Some times knowing the correct term to ask changes pricing dramatically. This failing you may be able to get it repaired. There is a company on eBay that offers Retina display service. Here's their straight sale: http://www.ebay.com/itm/LCD-Screen-Assem...
I'd check to see if this will one work on the 2015 even thought it's listed as being for the A1398, better to check before buying. They also offer a repair service. I have not used them yet so I can't vouch for them.
这个答案有帮助吗?
得分 1
添加一条评论
最有帮助的答案
I can tell for a fact that the other 2 models Dispay Assemblies don't work with the 2015 model. I'm having the same problem and tried both versions (2012 and 2013/2014). Although the screen fits perfectly and the connectors fit the backlight doesn't turn on.
这个答案有帮助吗?
得分 3
1条评论:
Thank you so much for this answer. We accidentally just tried 3 separate screens on our 2015 macbook pro only to realize we were installing the 2013/2014 lcd assembly and each time the screen worked but the back light wouldn't turn on. I have been banging my head against a wall. It sounds like we just ordered the wrong screen and *fingers crossed* the right screen will fix it.
完成的
添加一条评论
That's what I was afraid of - I guess I will give my local Apple repair a call. Why does Apple have to make repairing their products so difficult?
这个答案有帮助吗?
得分 0
1条评论:
添加一条评论
So I ended buying this from Amazon:
http://www.amazon.com/gp/product/B015NXP...
I can confirm that it does work perfectly. The one I got did have a slight bit of light bleed but considering it was the only one I could find I can live with it.
这个答案有帮助吗?
得分 0
2条评论:
Hello Gordon, did you end up just replacing the screen or the whole assembly? I'm looking to do a replacement and so far the signs point to replacing the whole assembly as replacing just the screen is extremely difficult? Thanks! Charles
完成的
I replaced the entire assembly as that was all I could find at the time.
完成的
添加一条评论
浏览统计数据:
过去 24 小时: 1
过去 7 天: 4
过去 30 天: 4
总计 8,718
