跳转到主内容
加入维修社区 - 创建账户
苹果 iPhone 5c 于2013年9月10日发布。该设备的维修与以前的型号相似,需要螺丝刀和撬机工具。提供GSM或CDMA / 8,16,32 GB /白色,粉红色,黄色,蓝色和绿色。
Touch screen not responding
My iPhone 5C fell off and the touch stopped working. There are no cracks, but sometimes you can see a brown (red?) grind pattern (image included). I found one topic connected with this problem and one member wrote:
I had this issue recently, where after a complete digitizer replacement, the phone turned on and looked great, but it no longer responded to touch and there was a strange grid pattern on the display. It turns out, under the adhesive piece that covered the digitizer's attachment to the main logic board, there was a tiny fuse that had fallen off. I am now looking for a micro repair place that can reflow this fuse back onto the main logic board. Make sure there isn't some other hardware damage.
Touch screen problems after screen replacement
Can anyone explain this to me? What can I do now? Can I see it (fuse) on some photo?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
Yeah, it's an issue with your digitizer. You could try taking it off and putting it back on. It's a thing I do, when a new one isn't co-operating. If you try this and it doesn't work. Remove the cables, disconnect the battery, reconnect the battery, then reconnect the display cables
iPhone 5c 显示屏总成更换
Worst case scenario you could buy another one from here
iPhone 5c LCD and Digitizer
Replace a scratched or cracked front glass digitizer panel or malfunctioning 4.0 inch 640 x 1136 pixel IPS LCD compatible with the iPhone 5c.图片
产品
$39.99
这个答案有帮助吗?
得分 2
1条评论:
Thank you, I will try to do everything you mentioned after I get some stuff (pentalobe screwdriver) and I will post the results.
完成的
添加一条评论
I have the same problem. Can you explain where is the fuse on the logic board and if the repair has worked ?
Thanks
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
iK0X 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 1
过去 30 天: 21
总计 1,271
