跳转到主内容
Model M2453 or M6411 / 300, 366, or 466 MHz G3 processor
Why can't I install OS 10.3 in this clamshell?
This machine (192 MB RAM) is currently running OS 9.2. Works beautifully. I have updated it with Firmware 4.1.7 update. Verified it as its Boot ROM is now 4.1.7f4. I booted off a cd 10.3 installer but after a few minutes of hard drive activity, I get a kernel panic. Tried it several times, I get the same result. Sometimes, what I get is a message that tells me I need to reboot the computer, blah blah blah, etc. I know this cd works. And 192 MB RAM maybe small, but it should have worked. What gives?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 -1
1条评论
添加一条评论
5个答案
已选择的解决方案
Are you sure you are using a retail disk (black) and not a machine specific (gray)?
这个答案有帮助吗?
得分 2
1条评论:
+ very good guess
完成的
添加一条评论
I could try resetting the PRAM. When you turn the computer on hold "Command[Apple]+Option+P+R" all at once, and keep holding it until it makes the boot noise twice. THen try and run the installation again.
这个答案有帮助吗?
得分 0
添加一条评论
Thanks, Chris. But resetting the PRAM did not change anything. Sigh
这个答案有帮助吗?
得分 0
添加一条评论
Yes, I'm sure the cd disk works, because I used it to install 10.3 in another clamshell weeks ago. Sadly that clamshell got inundated by a flood. It was a total loss, the water corroded many components inside. Mayer, thanks for the link. Although the Apple article mentions Powermac G3s as the affected models, I suspect a few clamshells were also involved. Thanks to all who responded.
这个答案有帮助吗?
得分 0
1条评论:
Try replacing the ram with the ram from the other G3.
完成的
添加一条评论
Yes, I've already changed RAM, even tried the 512 MB stick from another clamshell. Still no dice.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Bernie 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 1
过去 30 天: 3
总计 931
