跳转到主内容
Model A1312 / Mid 2011 / 2.7 & 3.1 GHz Core i5 or 3.4 GHz Core i7 Processor, ID iMac12,2
708 个问题 查看全部
Lower left part of backlight dimmed
Since a couple of months I've noticed that the backlight of my 27" Mid-2011 iMac was blinking slowly and iregularly.
Today it doesn't blink anymore but there is a big part at the left bottom which is now a little bit darker than the rest of the screen.
The content is still well-readable but there certainly is some backlight missing.
It doesn't show too much however because OSX has those semi transparent background stuff and in combination with the Yosemite backgrounds the issue is a bit hidden from plain sight. Changing to an all-white background though shows clearly what's wrong.
Are these backlight things changeable - or better - serviceable? There is no Apple store or service center around without boarding a plane.
Update (10/14/2015)
I wasn't keen on opening the iMac - certainly because I didn't have the sucker tools, but managed to do it without. Dirt easy with the ifixit step by step guides.
I was quite sure the 4 year old beast would be full of dust and rust, but it actually turned up to be cleaner than any computer I've opened up in my life. Just a little rust on the big middle iron piece and some minor dust on the 2 fans.
Closed it down, dark screen, opened it back up and reinserted all connectors, got white screen during startup and now I'm back in OSX back to step zero.
I'm not sad I opened her up though - it was a nice experience!
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
3条评论
Did you install Temperature Gauge Pro so you can see the temps & Fan data?
完成的
Just in case it may be related to a GPU recall issue, Please give us the last four figures of your serial number so we can check.
完成的
No I haven't installed that yet - will do that when I'm back at the office.
Last 4 figures of the serial number: DHJP
It is however a 27" i5 2.7Ghz with AMD Radeon HD 6770M, I don't remember this model ever had a recall except for the Seagate harddrive.
完成的
添加一条评论
1个答案
最有帮助的答案
You may have a heat issue. Did you open the system up and clean out the dust build-up? I would start there.
You may want to download this app to help you see the before and after effects of cleaning: Temperature Gauge Pro
这个答案有帮助吗?
得分 1
添加一条评论
添加你的答案
EDPR 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 150
