跳转到主内容
Samsung Galaxy S5 Active SM- G870A released June 2014. Repair for this device is extensive and requires the phone tool kit and heat gun.
Recover formatted partition in ROM
I formatted partition number 3, I have back up of it. But the device is never turn on after it, and it is not recognized by PC.
I guess I need to program the ROM memory.
How can I do it, and which tools, devices should I use?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
Hello Kostya Kostyushko,
  • Run Odin flash tool,
  • put your phone in to download mode (vol down/home/power button) and connect to PC via USB
* Tick re-partition box on odin tool
* Click PDA and select your stock official Samsung ROM
  • Flash and wait for reboot
You have to find Correct ROM and Odin tool for S5 Active.
Note : All data will be lost on your user data partition as you re partition the ROM & . Flash your device at your own risk.
Hope this answer help you to fix your dead S5
Cheers!
这个答案有帮助吗?
得分 0
4条评论:
This is a problem as I mentioned in my question, the device is never turn on. It means, I can't put it to Download mode.
I'm not sure what the 3rd partition is responsible for, maybe boot loader? But it seems I messed up this time.
Even if I connect the charger, it is not have any reaction. Completely dead.
完成的
Yes. it must be boot partition. you need JTAG flashing solution to fix you phone
完成的
Can you explain please? Never worked with JTAG, but I'm sure I can handle it if you point me. Thank you.
完成的
its a big topic which can't be explain in 1024 characters. simply you can find your self on web and see the YouTube guides, title = JTAG Flashing
完成的
添加一条评论
添加你的答案
Kostya Kostyushko 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 3
总计 836
