跳转到主内容
The Kenmore Direct Drive is a washing machine by Kenmore.
58 个问题 查看全部
washer won't drain, spin, or rinse, but it fills and agitates
washer fills with water and agitates but will not go to next step, draining, spinning, and rinsing. I have never had any problem of any kind with this machine. I just did a load 2 days ago, there was no different sound and laundry came out great.
It is a Kenmore 110 series top load. I hope you can help me.!! It is Saturday and I have a load sitting in water.!
Thank you,
Barry.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
barry, it is possible that you have defective lid switch. If so, the washer will not spin or pump the water out. The other things that can cause this is a defective or clogged drain pump. We would need a the model and serial number to give you more detailed instructions.
这个答案有帮助吗?
得分 1
2条评论:
It was the lid switch, I was able to get it to work till I can go to the store on Monday. My clothes are now in the dryer.
You were bang on the money.!
Thank you,very much,
Barry
完成的
You are welcome and best of luck to you.
完成的
添加一条评论
添加你的答案
barry 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 13
总计 4,302
