跳转到主内容
加入维修社区 - 创建账户
Why doesn't the Num Lock light turn on?
Corsair Vengeance K70 Mouse
My keyboard was doing fine until I noticed a while ago (a couple of days) that the Num Lock light that shows whether the Num Lock is on won't turn on. The Caps Lock and Scroll Lock lights turn on fine. This is a relatively new keyboard (< 1 year) so I don't know what the problem is. The Num Lock function still works.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
2个答案
已选择的解决方案
The Number lock feature can be enabled in the BIOS settings. Depending on the model of PC you can press F2 when promoted during the initial boot up to take you to the Settings. Scroll through the options and enable it. Hope this helps you.
You can also attempt to move the keyboard to another USB port to see if this also resolves the issue.
这个答案有帮助吗?
得分 2
添加一条评论
probaly a bad led
try replacing the led
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
James Leung 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 10
过去 30 天: 42
总计 6,006
