跳转到主内容
Repair guides and support for electric and gas-powered high-pressure sprayers sometimes referred to as power washers.
38 个问题 查看全部
Simoniz pressure washer leaking from gold spring thingy
Hi there I have a pressure washer that's leaking water out of a gold spring thingy I'm not sure what it is or how to fix it any help would be appreciated
Update (10/08/2015)
Gold spring thingy
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
Can you elaborate? Could you provide us with a manufacturer, model number, or year? What is the "gold springy thingy?"
完成的
添加一条评论
3个答案
最有帮助的答案
Hi Mike - That gold springy thing is the adjustment spring for the unloader valve. It makes it so water flows even when the trigger isn't in use. This keeps the pump from running dry. Inside the spring is the adjusting bolt. You should be able to tighten and loosen the bolt to adjust the unloader pressure. I would assume these things were done in the factory before shipping to you but possibly you may need to loosen off the nut to stop the leak. Another possibility is an o-ring/nut has cracked where the water is leaking through. All in all this is definitely something that would be covered under warranty.
Sources for further reading:
http://www.ppe-pressure-washer-parts.com...
http://pressurewashr.com/pressure-washer...
http://www.epowerwash.com/wp/archives/63...
这个答案有帮助吗?
得分 2
添加一条评论
Sources for further reading:http://pressurewashr.com/pressure-washer...
这个答案有帮助吗?
得分 2
添加一条评论
Hi, Mike. That's a Great question . This keeps the pump from running dry.It makes it so water flows even when the trigger isn't in use. Even I appreciate with @jamar . Aslo Tnq @jamar for providing your valuable opinion . Thanks to all. Washer Daddy
这个答案有帮助吗?
得分 2
添加一条评论
添加你的答案
mike 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 17
过去 30 天: 46
总计 3,720
