跳转到主内容
加入维修社区 - 创建账户
Why doesn't my power cable light green and properly charge battery?
About a year or more ago I noticed that the little light on my magnetic charging cable no longer lit up when attached to the computer.
When I jiggle it, it will eventually light up and show either green or orange (depending on how much of a charge it needs). However, it will very shortly go dim (and sometimes go totally out) and sometimes it doesn't charge my battery.
This has caused the lifespan of two different brand new Apple laptop batteries to be very short. I've cleaned the connector area of all particles and looked all over on the web for what to do about this, to no avail.
Can I replace the "charging port" on my laptop? If so, how do I do that and where can I buy that part? I have already tried replacing both the battery itself and also the charger. Both were official Apple parts purchased from the Apple Store and neither option has helped with this charging problem.
Please help.
Sincerely,
Edwin
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
After checking the AC adapter pins with a toothpick to make sure they are extending, I would replace the left I/O board. Here's the part: MacBook Pro 15" (Model A1211) Left I/O Board
Here's how to replace it: MacBook Pro 15" Core 2 Duo Model A1211 Left I/O Board Replacement
Replace an I/O board compatible with the model A1211 MacBook Pro 15" laptop. Fix problems with charging, audio, and data connections. Includes the MagSafe power, USB, and audio ports. Includes slots for internal Airport wireless card and PC Card ExpressCards.图片
产品
$29.99
这个答案有帮助吗?
得分 2
3条评论:
完成的
Thanks!
I checked the pins, and they look okay.
I'll order a new I/O board and hopefully that'll be all I need.
Appreciate the help!
I'll let you know how it goes.
-EA
完成的
hi Edwin !did you replace the i/o board ?
does ist work ?
完成的
添加一条评论
添加你的答案
Edwin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 0
过去 30 天: 3
总计 2,688
