跳转到主内容
加入维修社区 - 创建账户
1.6 或 1.8 GHz 双核处理器,2 GB 或 4 GB SDRAM,64 GB 或 128 GB SSD
Keyboard row doesn't work
Whats up guys, I JUST finished changing my battery on my macbook, and now my a s d f g h j k l keys don't work, all other keys work fine. I was wondering if I might have loosened the keyboard cable or something. I'm going to take it apart again and see if anything is loose. Which cable is the one for the keyboard? Thanks.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
已选择的解决方案
I'm sorry that you're having trouble with your keyboard. Unfortunately, Apple (we all know the designers at Apple can do this if they are feeling dubious) has decided to embed the keyboard in the upper case in your model, and the keyboard cable and assembly is in the upper case. Depending on how many repairs you have done before, this could take anywhere an hour for experienced professionals to three hours for beginners. If you want to proceed, you can use this guide (MacBook Air 11" Mid 2011 上盖更换) to try again. You also may want to reseat the battery connector before trying. Hope this helps.
这个答案有帮助吗?
得分 1
1条评论:
Good news, I removed the battery and wiggled the ribbon connectors and reassembled everything and it worked. The keys are working now haha I guess I got lucky. Thanks for your help anyways
由完成的 分享
添加一条评论
添加你的答案
Mark Chang 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 21
总计 448
