Check under the dash to see that nothing has got shoved up into the flap to keep it from moving or that the flap has not been pushed into the housing and is stuck in the closed position
My 2005 Honda pilot jerks when I take off on freeway and after shifts fine runs good some days I have to turn off because blinking lights like the D and a ! I turn off then on and it's fine what can it be
can you move the cable while it is not connected? Can you move the valve manually? What year is your Pilot?
由 oldturkey03 完成的
由 Jimfixer 完成的
