跳转到主内容
加入维修社区 - 创建账户
2014 年 2 月发布的 10.1 英寸平板电脑,运行三星定制版 Android 4.4 KitKat,型号为:SM-T520NZKAXAR
Won't turn on, won't charge battery
Hello! I open this topic becouse I think this is a diferent problem from the other topics.
I try to fix a SM-T 520 how won't turn on. I replace the USB charge flex cable but it Still not working. With multimeter it is possible mensure 5,4V in one diodo in motherboard when it plug to charger (the current arrives to motherboard) , but in the battery plug pin's arrives only 0,2V how it's not enought to charge battery. The battery shows 3,7V and I think it's not enought to turn on the device. Next week I will try to connect to a variable power supply to know if is a battery problem but I don't beleave. I try every possible reset solution but it don't turn on and it don't show's any led light when it plug to charge. Thank you
Update (10/04/2015)
Picture from the motherboard
Update (10/05/2015)
Another picture from the motherboard.
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
3条评论
Good picture but it shows only part of the board. For the charging circuit we need to see the rest of it as well.
完成的
Its further to the left under an EMI shield :-)
完成的
添加一条评论
1个答案
已选择的解决方案
rubenmplopes, just because you got some 5.4V on a random diode, does not mean that your charge connector is working. I would suggest that you measure on the connector itself. If you only got 0.2V on the battery connector and if your charging port shows the proper voltage on the pins, then you do want to check the power management IC as well as other components on your charging circuit.
Update (10/04/2015)
Use this guide to add images.
这个答案有帮助吗?
得分 1
5条评论:
Thank you for your answer. I allready check the charger cable how plug to motherboard and somewhere in the ribbon cable I mensure 5.4V. Next step is find the power manager IC... I can't find any motherboard schematic on web... Another thing I forgot to tell is the tablet works fine untill battery drained. After it don't charge and don't shows any signal.
完成的
"untill battery drained" sounds like either a bad battery or bad PMIC. Post some good pictures of your logicboard with your question, that way we can identify a few parts for you.
完成的
You can see the picture from the motherboard
完成的
I post another photo
完成的
Hello oldturkey03 did you find any solution? Thank you
完成的
添加一条评论
添加你的答案
Ruben Lopes 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 5
过去 30 天: 29
总计 2,854
