跳转到主内容
Repair guides and support for videocassette recorders including Betamax and VHS (Video Home System) players.
59 个问题 查看全部
VCR won't load cassette. Cassette doesn't drop down when pushing it in.
Hi,
I have a Toshiba V-804G VCR that no longer loads cassettes. I removed the lid, and can see that when I push in the cassette, it doesn't go down all the way. The gears of the white part on the right in picture 2 turn and make noise, but don't seem to do anything. The mechanism at the arrow tip in picture 4 doesn't go down around the corner as it should to drop the cassette into place.
We've had this VCR for a long time, and I'd like to get it working again, especially because it can play both PAL and NTSC tapes, and we have quite a selection of both.
Any repair tips would be greatly appreciated. Thanks!
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 2
2条评论
P.S. I speak English and German.
完成的
I can not load a vcr tape into my vcr
完成的
添加一条评论
4个答案
已选择的解决方案
rickfilms, check the loading motor sensors etc. See if this will help to get started:
这个答案有帮助吗?
得分 4
1条评论:
Did you manage to finally solve it? I'm having the same issue..the icon at the display tilts as if the vcr already had a tape inside, but so far this is all I could find out..
完成的
添加一条评论
Hey, it's possible that the mechanism skipped when unloading the last time, this means that things are happing at the wrong time. Does it sound as if it is jamming? the other thing to check is if there is a belt drive below it, I know they stopped using belts for this use, but maybe this one has one in there.
When faced with this I would have turned off the power and manually turn the small wheel to see when it stops, that is another this ti t ry.
Good luck
这个答案有帮助吗?
得分 1
添加一条评论
What I did with my digital samsung VHS , was literally hold the tape down until the light comes on (whenever a tape is inserted, I also removed the top off and screws but and pop it on/off).
after a couple of seconds, the VCR detects a tape in and the tape itself goes thru the motions (gears , head).
then I play it, but it may eject/stop/rewind a little but after 5-6 times or more (keep putting tape in and holding down) it'll eventually play. But this has to be done each time.
这个答案有帮助吗?
得分 0
添加一条评论
Please help i have the same problem and i really want too watch some vhs on my crt :(
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Rickfilms 将永远感激不已
浏览统计数据:
过去 24 小时: 23
过去 7 天: 103
过去 30 天: 317
总计 40,786
