跳转到主内容
加入维修社区 - 创建账户
Repair information on hard drives or hard disks. Hard drives are magnetic data storage devices. They are used in most desktop, laptop, and server due to their low cost and high data density.
Suddenly I can't save files on my external hard drive anymore!
I have Sony external hard drive HD-E2, and it was working fine; I could save files on it and copy files from it. But then, suddenly, I was only able to read from it. I find it odd since it was working great for almost 4 months.
My laptop is MacBook Pro.
However I started to have this problem after upgrading to El Capitan MacOS.
Could this be somehow related or relevant to the problem?
How to fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
3条评论
I have a WD Passport HD with 4TB. When I bought it, I partitioned it, so that I could use one partition for Time machine, and the other for extra files. Now the Time Machine partition is writable, but the other partition is readable only. I cannot copy files onto it anymore. It may be due to an upgrade in my OS. I’m running High Sierra. I’ve tried to change permissions in the INFO section of the partition, but everything is greyed out. How can I get read and write permissions without having to reformat the whole HD? Thanks for your help.
完成的
I have an intel tower that has a write disk drive. I have put a disk and I am unable to save files to the cd drive.
完成的
Yesterday my seagate 4T portable had strange sound like engine metal scratching , today sudden death, so bad seagate quality . i will never buy seagate in my life
After scan disk successfully, some movies file still cannot copy out
maybe due to bad sectors or 1 of the pin heads dead
this seagate 4T portable is 3 months ago given by seagate recovery lab
完成的
添加一条评论
6个答案
已选择的解决方案
1. Shot in the dark - try running Disk Utilities and repair the permissions.
2. Click once on the drive, go under File to "get info" and see if you have Write permission.
这个答案有帮助吗?
得分 3
8条评论:
My Toshiba Portable is having the same problem after my recent upgrade. It is showing that I do not have write permission. Is there a way to change it so that I can write again?
完成的
Cj I'm strictly Mac. Please ask a new question and tell what machine you are using and what OS.
完成的
I'm sorry, I have a macbook pro.
完成的
I'm on windows 10 and I don't have admin permission to change that. I can't even change myself to admin.
完成的
完成的
显示更多的3条评论
添加一条评论
https://www.boxaid.com/blog/fix-read-ext...
For those still struggling: I have a Seagate External HD that was never partitioned for Mac as I use it to share files between Windows and Apple computers. Suddenly I wasn't able to write/copy files to the HD (maybe due to upgrades of my MacOS?). Followed the advice of this website and downloaded the recommended helper for Seagate. Very helpful.
这个答案有帮助吗?
得分 1
添加一条评论
The best solution for this is reformatting your external hard disk or check for errors in hard drive. Some times you received permission error, and you just need to ignore permissions.
这个答案有帮助吗?
得分 1
1条评论:
What if i can't afford to lose my files??
完成的
添加一条评论
I could not do either. It says under permission it has read and write. But just above it says you can only read. I used this disk on mac only for the last two years.
这个答案有帮助吗?
得分 1
2条评论:
I have the exact situation as bhandr
完成的
I have the same situation did you ever solve this?
完成的
添加一条评论
Mayer was correct!! i I right clicked on the drive from the desktop and choose “get info”. you will need to unlock the drive located on the bottom right hand corner. put in your password and put a check next to “ignore ownership on this volume.” lock it back up and try it. .it totally worked for me.
这个答案有帮助吗?
得分 1
2条评论:
Not clear. Bottom right corner of which window.
完成的
I didn't find the above mentioned option anyhwere. Help
完成的
添加一条评论
Anyone reading this, I did a combination of things that finally worked. Partitioned the drive in half (so my saved stuff was left alone.) Formatted the new partition by “deleting” it. This created a new icon on the desktop to the newly formatted partition. Double-clicked on the new drive. Select “get info” (upper right button), then I unlocked to “ignore ownership.”
Finally I went back to the application that was not allowing me to save to that specific location, and I hit “search" or “find” and then typed in the name of the partition I gave it (default name is “untitled” but it will be whatever you name it above, or how it appears on your desktop). Then the application finally found it. Lastly, clicked on it, and then it allowed me to save to the External drive. I am currently copying files, god bless it.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Moath 将永远感激不已
浏览统计数据:
过去 24 小时: 2
过去 7 天: 12
过去 30 天: 59
总计 63,754
