跳转到主内容
加入维修社区 - 创建账户
The Asus Padfone 2 was announced on October 16 2012 and is the successor to the Asus Padfone.
wifi doesn't work on padfone 2
Hello! after i have bricked my telephone, i was able to repair it, and i re install the lastest firmware, all works, but no wifi!!!! i think it's a software's problem.. it see the networks, i try to connect, but nothing, only "connecting" , and stop.. how can i solve it? i have changed some firware, uffical and rom.. re install the wifi driver? but how? thanks..
i attacched this screen for some informations..
回答此问题 我也有这个问题
这是一个好问题吗?
得分 1
2条评论:
hvae you installed CyanogenMod (custom ROM)? which OS is currantly running on your phone ?
完成的
4.4 official, no cyano, i tried other rom with 4.4 or 4.1.. but nothing
完成的
添加一条评论
1个答案
Dear psycho91,
Wi-Fi TRX not functioning on your phone. that is the reason to get RSSI -200 (Ordinary Wi-Fi RSSI range is -20dbm to 120dbm) you will have to replace Wi-Fi + BT module on your logic board.
Vocabulary
RSSI means Received Signal Strength Indicator
TRX means Transceiver
这个答案有帮助吗?
得分 0
1条评论:
thanks, but i try in another house, and work, i went to mine and work... for now.. yesterday same problem.. don't connect!!! it's probably a software problem
完成的
添加一条评论
添加你的答案
psycho91 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 4
过去 30 天: 9
总计 540
