My Camera Stops Recording After Several Minutes of Video
My camera goes for about only two - three minutes before it stops recording. What could be causing this and how do I solve it?
Check to make sure there is available space on your memory card. If your memory card is full it will prevent you from being able to record videos.
I would also check to make sure you are using a compatible SD card. All GoPro cameras require a minimum of a Class 10 SD card. Keep in mind that video files are very large, especially 4K video. A lot of memory will be required for longer videos. for more information check out the GoPro Here4 Silver's troubleshooting page.
这个答案有帮助吗?
过去 24 小时: 1
过去 7 天: 3
过去 30 天: 3
总计 3,577
