跳转到主内容
This is the first generation of Amazon Fire TV (model CL1130), released on April 2, 2014. It is a powerful media streaming and gaming device that allows the user to stream digital audio/video content to a high-definition television as well as play video games.
Why can’t I get internet access with a wired Ethernet cable?
When I try to connect to the internet using a wired Ethernet cable connection, the Amazon Fire TV will act as if there is no internet connection. What can I do to fix this problem?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
2个答案
已选择的解决方案
There could be a couple reasons for the Internet connectivity problems. Maybe the Ethernet cable is not correctly connected, or the router is not providing Internet access. Maybe it's also a hardware problem, in which the Ethernet input port may be damaged. For more information, visit
Amazon Fire TV Troubleshooting
这个答案有帮助吗?
得分 0
3条评论:
useless information. how is this solved ?
完成的
I use the Amazon Cube 2nd Gen. When I connect ethernet Have to cut off Wi-Fi The problem that I have I cannot use my Amazon echo's Because when I cut off the Wi-Fi on Amazon cube It disable everything else So I have to use either or
完成的
Hasn't solved my problem must be problem with new fire stick
完成的
添加一条评论
Why won't my internet is not working what is going I have xfined
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
cory burke 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 2
过去 30 天: 12
总计 14,559
