跳转到主内容
这是 MacBook Air的维修指南,MacBook Air是Apple的一款面向消费者的笔记本。
4825 个问题 查看全部
change the LVDS cable on A1465 and A1466
Hi
Are there are guides or videos in changing the LVDS for A1465 and A1466? The cable on both of them is burned. Do I have to separate the layers of the screen or is the cable accesable once the bezel is taken off?
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 1
添加一条评论
1个答案
已选择的解决方案
No, the screen has to be taken off to access the cable inserts in the LCD. I am not aware of anyone doing a guide on this, I could be wrong. I may be doing one the first of next week so I'll try to take pictures if I do it.
这个答案有帮助吗?
得分 1
3条评论:
Another question. Are the screens interchangeable for testing purposes? I wanna connect a A1466 screen assembly to the A1465 to see if the board connector is good.
BTW. Thanks for the reply. I needed the answer badly.
完成的
I have no idea on that one, haven't tried it. But on standard MBP they are not interchangeable on the 13 & 15" models. Connectors are different.
完成的
thanks. for clarification. are there connectors different electronically? Because on many PCs you can connect a 15" screen to 17" laptop and it works fine (for testing purposes).
完成的
添加一条评论
添加你的答案
garegin 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 10
过去 30 天: 12
总计 1,174
