CPU Upgrade question. Help Me..!
Mac Pro Late 2013 CPU Replacement 'Mac Pro Late 2013 CPU Replacement
STEP 23.
I can not remove the screws . A screw is changed shape ....
What can I do ? Any help?. I am going wrong ..
Thanks so much...!
STEP 23.
Thanks so much...!
I think I know what you're referring to. A few months ago they started putting tamper evident stickers on the top of the 4 screws holding the CPU bracket in place. By applying light pressure to the center of the screw the torx 10 will puncture the sticker. It threw me for a loop too when I first saw it too.
这个答案有帮助吗?
You are very correct! Apple added tamper tags. Their getting to be like Rolls-Royce!
The screws DO have T10 Torx heads. There's just a tamper stick on top of the screws now hiding it. There's no need to wreck the screws and the bracket (which apparently you did) with any kind of brute force with needle nose pliers. All you have to do is use the T10 screw driver and apply pressure to the middle of the "blank" screw. The T10 screw slot will reveal itself when you apply enough pressure, and then you can simply screw them out. You can definitely re-use the screws afterwards. It's just a stupid black tamper stick that they stuck on top of the T10 torx screw. So definitely do NOT listen to Jon Spinella's advice and wreck your screws and bracket.
这个答案有帮助吗?
过去的24小时: 0
过去的7天: 2
过去的30天: 3
总计 859
What do you mean it's changed shape?? The screws are Torx screws (T10). Are you using the correct screwdriver here? Some poeple confuse the Torx for Allen or Spline which are different.
由 Dan 完成的
There are also T7 screws. How about a picture or tell us what step on the guide you are having issues with. Did you strip a screw out?
由 mayer 完成的
I know this is old but for anyone else seeing this, the screws no longer have T10 torx heads. They are flat, no holes, no slots and you'll need to carefully use needle nose pliers to remove them (and replace with T10 torx screws like I did). I replaced the entire bracket and screws since they get a little scratched up during removal. Be very patient and careful to not slip and damage something on the board.
由 John Spinella 完成的
@spudnuts where did you get the t10 screws and the bracket???
由 Carlos Blanco 完成的
I would like to know where did you get the t10 screws and the bracket also
由 timmy123 完成的
显示更多的2条评论
