跳转到主内容
Second generation phone released in November 2012. Available in stealth black or polar white / 32 or 64 GB / micro sim card / no sd card slot. Model #PM63100
8 个问题 查看全部
My device will not charge or power on
A few day ago my phone was running low on battery consequently it turned itself off, later I plugged it in to charge it and left it to charge for about an hour. I came back and pressed the power button and the phone would not turn back on.
So my question is, is there a way to fix this issue, would I have to replace the battery or is the fault elsewhere?
回答此问题 我也有这个问题
这是一个好问题吗?
得分 2
添加一条评论
1个答案
First ensure that the charger to your cellular device is not the issue rather than the battery.
  1. Check to see if your phone charger works with another device that has the same charging cable.
  2. If this does not work buy a new phone charger because your charger has gone bad and is the reason your phone would not turn on.
However the charger does not seem to be the issue considering your phone turned off while it had a percentage of battery remaining.
  1. Remove your battery from the device in order to replace it with a new one.
  2. Replace the battery in your device with a newly purchased HTC one x plus battery
  3. In order to complete steps 1 and 2 follow the battery replacement guide guide for a detailed step by step process on replacing the battery.
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
Ian Dodge 将永远感激不已
浏览统计数据:
过去 24 小时: 1
过去 7 天: 2
过去 30 天: 2
总计 207
