跳转到主内容
Second generation phone released in November 2012. Available in stealth black or polar white / 32 or 64 GB / micro sim card / no sd card slot. Model #PM63100
8 个问题 查看全部
问题已关闭
Why does my phone not connect to Wifi networks?
Recently, my phone will not connect to the WiFi in my home. I have tried turning my phone off and then back on. I have also tried putting it into airplane mode and then reverting back to receiving signal and it does not help either. Furthermore, my phone has plenty of battery and none of my settings are askew.
回答此问题 我也有这个问题
这是一个好问题吗?
得分 0
添加一条评论
1个答案
  1. Ensure that your WiFi setting is enabled so that your antenna is activated and searching for networks.
  2. Find your home network name and click on it to connect.
  3. Type in your password for network access.
If this does not work then there may be a problem with your router.
  1. Unplug you router and then plug it back in order to restart the modem.
  2. Repeat steps 2 and 3 from the first set of steps.
If this does not work please refer to this troubleshooting page for more information on WiFi connectivity issues.
If all of the above steps don't solve your problem, replacement of the antenna will be necessary. This antenna replacement guide should be able to help you.
这个答案有帮助吗?
得分 0
添加一条评论
浏览统计数据:
过去 24 小时: 2
过去 7 天: 2
过去 30 天: 2
总计 100
