跳转到主内容
The Nissan Altima is a mid-size automobile manufactured by Nissan, and is arguably a continuation of the Nissan Bluebird line, which began in 1957.
148 个问题 查看全部
clutch adjustment nissan altima
how do you adjust the clutch on 2002 nissan altima
已回答! 显示答案 我也有这个问题
这是一个好问题吗?
得分 3
添加一条评论
2个答案
已选择的解决方案
Donna,
The 2002 Nissan Altima has a hydraulic clutch and it can not be adjusted. The only thing you may be able to do is adjust the pedal travel. There may be a nut with a threaded rod on top of the pedal attachment point under your dashboard.
If the clutch feels funny, try bleeding it. If that is not working, try replacing the fluid. If you still have a problem you may need to replace the clutch.
Regards,
Frank
这个答案有帮助吗?
得分 3
1条评论:
Works for me +
完成的
添加一条评论
I got a 2003 Altima and and the gear shift is locking up
这个答案有帮助吗?
得分 0
添加一条评论
添加你的答案
donnalyns1020 将永远感激不已
浏览统计数据:
过去 24 小时: 0
过去 7 天: 7
过去 30 天: 29
总计 7,419
